Looking for composite material *see inside
badmix
West Virginia
Long story short, working on a DIY project. I could use Plywood, but want something different. Im trying to find some composite material. I need sheets of 10' x 8' respectively.
Im going to build a TearDrop type trailer for off roading.
Below is what im looking for, just need to find it in the USA.
http://www.monopan.de/index.php?id=8&L=1
what kind of skin are you looking for, alum or fiberglass?
pretty common in my trade.. haven't used any honeycomb/core stuff in a few yrs, but i can certainly find a local distributor easy enough... can't vouch for pricing tho, it certainly isn't plywood money.... and i doubt sheets that large are available, iirc, they come in 4 x 10's...
Nidacore. go to their website and fill out the info sheet, they will send you a sample box of nidacore products. Their small squares, but they have different types to fit your needs. And they do come in large sheets- though 10x8 might be a special order, and you'd have to get it through your distributor.
Im going with plywood. Easier to work with, cheaper and readily available.
Thanks everyone. :D
