looking for suggestions on speakers
gjk5
3/4 ton status
Grand Junction, CO
I currently have the cracker engineering style speakers (home bookshelf speakers wired in and bungeed down in back) I am thinking about one of the following solutions:
Cheapie wally world speakers ( I think they are "Lightning Audio") 220W 6x9's and enclosures for the back for around $60
Decent marine speakers and enclosures for the back.
My reasoning behind this is I usually have the soft top down most of the summer and don't want to spend big $$$ for speakers that will get wet anyway so either cheap or "water resistant" seem to be the way to go.
Oh, this is in a '72 K5.
Also, anyone ever put small (like 4") speakers in the door panels? and will this do anything with the top down? (i.e.: will I hear them)
Thanks
My buddy's cabin crusier (boat) has Clarion speakers that sound really good. You might want too surf the net for boat web sites too see what speakers are available.
Out side of Rain, you could make the box hard to remove them from a honda that the window can be broke.
A Slot loaded ban-pass box bolted to the floor with the amp in the side, if you have rear Sides, with the box bolted to the floor.
I have checked on marine, about $100 for 6x9's (clarion or similar), about the same as a pretty decent pair of regular speakers. I am just thinking for an acoustical nightmare like a lined tub, convertible, 33 year old creaky K5 with cherry bombs it may be a waste for upper-end speakers. I just see this crappy "Lightning Audio" wally world ones and think what the hell, pretty much diposable.
Not sure what the honda part means, but I don't think I'll get much bass with the setup I mentioned (old ass truck with no sound deadener and a soft top)
Check Ebay. They have lots of waterproof marine speakers for cheap. Got a set of 6x9s for my boat. For $47 including shipping last year.
Hey, thanks for the heads-up. i looked on ebay and there were a bunch of marine speakers cheap. I did notice that most had lower wattage ratings than your standard speakers though.
Don't know what some of the technical stuff means though anyone wanna fill me in:
Key Features350 Watts Peak Power Handling50 oz. Magnet4 Ohm Impedance60Hz - 20kHz Frequency Response92 dB SPL (1 watt/1 meter)Poly Injection Cone Material1" Aluminum Voice Coil1" Mylar Dome TweeterPlastic Grilles
You don't neccessarily have to have all out marine speakers if they're just gonna get wet, just make sure you buy something that doesn't have a cone made of paper. Most marine speakers are made for highly corrosive saltwater environments. Aluminum cones and rubber surrounds usually work well for what you're talking about. If you must go cheap and use paper cones, mix white elmer's glue with water (no, I'm not kidding) and apply a thin coating to your speaker cone. This will essentially seal the paper and prevent it from sucking up water if they get splashed. And if you're gonna spend time cutting holes in the door for speakers, put 6.5"'s in there. You'll never get a decent sound from a 4" speaker, I've had some of the best, and they all suck.
