Wanted Looking for turbo 400 or 4l80e 241-c adaptor
Classiccar
Registered Member
St.louis mo
Looking for a transfer case adaptor for a turbo 400 or 4l80e part number 15654927 let me know what you have.
has to be 400 or 4L80-e specific unless you plan to get the aftermarket special index ring .the bore that holds the o-ring is bigger on 4L80 so its to big for a 400 or a 400 is to sloppy and not centered in a 4L80 . and the mounting feet are clocked wrong on some . i know 205 is and not sure on 208/241 t-case setups . so the wrong feet will hit the pan on a 4L80-e .
hope this helps and good luck .
Thanks for the info
hope this helps and good luck thanks for the info
So based on this new info which are you looking for?
I have a few of the th400 in different shapes.
Not sure if I have more than the one I need for my 4L80E /241
I have an 4l80e but I was told one off a turbo 400 would work but sweetk says different so I trust him.
Yeah, as he said it can be made to work, you need the sleeve but if you find a 4L80E adapter it's easier, and they are plentiful, unlike the 205 adapter, one year only
