buffblazer
86 k5.
did a axle swap to 60 front 60 rear, drums in back, all new pads, lines and cylinders. no leaks in the system that i can see.
when driving, every once in awhile i will hit the brake and the pedal goes all the way to the floor. then i pump it and it comes back after a bit.
figured it was a vac issue so i replaced the brake booster. still have the same issue.
thoughts?
thoughts?
