GsxrMike
Ok so I feel sort of like an idiot because I changed my oil before an event and I used mobil one full synthetic (I have only changed the oil in the motor once before and I used conventional) and now my motor is loosing oil pressure. It ran great all day right up until the last hill climb that I attempted and my oil pressure dropped to 0. I rolled the truck down the hill until I couldn't avoid a tree and had to restart. Motor fired up and ran up to 20 psi, I got around the tree and shut it down again. I had plenty of oil so there shouldn't be any issue with the pick up coming out of the oil. My symptoms are: Motor is cold I get 45-50 psi at a fast idle, motor is warm I get 15-25 on flat ground, another thing I notice was at one point I had about 30 psi but when I put the motor into gear it dropped to about 10-15 psi and there wasn't a huge drop in rpm. I had my idle set at like 1000 and the rpms dropped to maybe 850-900. The other clue is if I try to drive up a hill I loose all oil pressure, I don't know if it has anything to do with the angle on the motor or just the fact that I am putting the motor under a lot of load.
What do you guys think? Did I f up my motor with the synthetic? If so is there anything I can do short up a rebuild? What else could it be? Oil pump, cam bearings, dizzy gear? Thanks in advance!
