The key warning chime is a different switch, just below the turn signal switch. The ignition switch is lower on top of the column.
Don’t buy a distributor on EBay. Either get the AC Delco remanufactured, ( they don’t make new anymore), or a new Delphi CZ20001, (this is new). Makes sense to just buy one of those complete, rather than replacing all the parts. Almost the same money (well not quite) and much easier to have one ready to drop in. You did mark position before pulling it right? Just thought I’d askUpdate, Ok Members I Thank you for all the input and help. It’s been a rough week already and it ain’t over yet. I removed cap/rotor. The contacts on both were blackish stained. They are Accel parts. The top under cap which fits on the spline is rusty. The pickup coil wires are brittle and twisted cracked. I pulled the distributor to repair install new pickup coil and whatever else it needs. Is there supposed to be some magnetic effect when shaft is spun ?? If so there isn’t any. I did purchase some AC Delco parts. Coil, pickup coil, module and ignition switch. Once I seen the condition of distributor just doing half a repair work won’t work so I pulled it. I hope I can find any other parts to rebuild it. I found several distributors on EBay and will at least purchase one or both as backup or use. If I could have found a new OEM AC Delco distributor I would have bought it to save time. I will check local part stores for additional rebuild parts. This might be a step in the right direction. Let’s see how it goes
Hello Members I pretty much found all parts to rebuild my distributor. There’s a piece called a tang shim/washer and a washer. The washer shows some wear and tang washer doesn’t. What should the play or
Clearance be. It didn’t originally appear to have excessive lash or play.
dyeager535. Yes it’s the one washer commonly called maybe a thrust washer. It fits front of gear. I purchased a new one to check the lash if I installed it. With the original one in it was .021 new one was slightly snugger. I forgot the correct terminology. So I just kept old one in. It didn’t show really any wear. The other part that fits before washer is called teng washer. It has three arms and each arm goes into bottom of distributor housing. So if somehow I guess the distributor has to much play or side movement it will show on these two pieces.
