lots of chev parts/more added
74 chev
Concord,CA
Brake proportioning valve $10
3 inch raised steering arm $10
1.5 inch sway bar drop brackets $10
Alternator $15
Flex fan $5
Four rancho six inch lift shocks $25
600CFM Carter carbuerator $50
Starter $10
Power steering pump 1973 $25
73 chev throttle cable $15
TH350 flex plate $20
1973 chev instrument cluster $25
GM 12 bolt Brake drum in good shape $10
stock TH350 tourqe converter $20
76cc sb 350 heads need to be rebuilt $50
1 inch add-a-leafs for a 73-87 chev $25
1/2 ton 5/8ths thread u-bolts 13.5 inches long for a 5.5 inch lift block $20
1/2 ton rear spring plates $10
1/2 ton front spring plates $10
4.09 gears for a dana 44 in great shape $30
14 bolt FF 3.73 gears in great shape $25
14 bolt FF axle shafts $25 each
14 bolt FF hubs $50
front driveline for 74 chev with 203 t-case all new u-joints and a new cv-joint $30
1973 chevy truck complete wiring harness in great shape $50
1973 master cylinder $10
1973 brake booster $10
1973 sb350 stock valve covers $10
4 Eagle Alloy 1430 series aluminum rims 16.5x9.75 in great shape with hev 6 lug pattern $350
4 38x15.50x16.5 SSR Radial super swampers 75% with no damage at all $900
Extended rear driveline for 8 to 10 inch susp lift with brand new tube and u joints and a new slip yoke. it came off of a long bed chev with 9 inches of lift and sm465/203 $75
Re: lots of chev parts
I'll take that conversion ujoint, pm'd ya
You selling the VIN and title for that 73 also?
Eric M.
wow, you're in longview... my fiance is from longview and still works there. small world! anyway, i may be interested in your ff14b shafts. How are the splines? any rust or other damage?
j
nope no rust and the splines are in great shape.
