This is pretty much what I settled on. I did slide the axle forward 1.5" though with the Zero rate.
My longer rear shackles were interfering with my cage supports so I swapped in a set of ORD stock length shackles and removed the rear block.
My spring packs are pretty soft so we will see where I end up on the cuts.
