Big6ft6
***just updating for future forum surfers to recant my previous claim that I fixed this issue - Changing oil filter only fixes the problem temporarily, it eventually comes back regardless of filter type and especially in cold weather, no fix or cause known at this time***
****original post below*****
91 TBI 350 with 170k miles. Recently (since cold weather?) the oil pressure gauge has taken a long time to register any oil pressure after I start the engine. Like 3-5 minutes
!! After this it seems to register ~30psi or so and not vary much with RPM. I've only driven it half-dozen times or so since this started.
Prior to this, it would always read really high...sometimes pegging the oil pressure gauge and it would vary quite a bit with rpm.
I repalced the sender (under the distributor) today and it still reads zero at start up which leaves only two possibilities..a bad gauge or I actually have no oil pressure. Is there any easy way to confirm oil flow at start up? Is there an easy place to stick an analog oil pressure gauge?
Any ideas?
!! After this it seems to register ~30psi or so and not vary much with RPM. I've only driven it half-dozen times or so since this started. Prior to this, it would always read really high...sometimes pegging the oil pressure gauge and it would vary quite a bit with rpm.
Any ideas?
also every time in my automotive tinkering that I think my problem is something terrible/complicated/lethal...it ends up being something simpmle (like a gauge)....but there is a first time for everything
