1989 K5 will not start found that fuel wasn't getting to the TB, replaced filter didn't fix the issue, put a test light to the fuel pump and found very low voltage to the pump, traced wire back to fuse block very good power to the fuse block but low voltage coming out not sure what to do next. Any suggestions would be greatly appricated.
