Had this happen to me in utah on a job. I was convinced it was the fuel pump. Ended up being the map sensor at the back and top of the intake manifold.
Hmm that’s weird. I’ll have a scanner tomorrow so hopefully that’ll show me if it’s the MAP
No. Mine would die in flight. Occasionally restart and run like crap and then die again. Start and die right away.Your map sensor was causing low fuel pressure???
Won't help if your fuel psi is below spec. If you decide to replace said sensor look it up on rock auto under an 04/5 silverado 2500. Find the delphi number and run it on ebay. A lot cheaper than the local chain auto part stores.Hmm that’s weird. I’ll have a scanner tomorrow so hopefully that’ll show me if it’s the MAP
I've only used the port a few times to look at the fuel psi. helped me discover that my psi was bleeding off. I ended up putting a one way check valve in front of my corvette fuel filter and she has been happy as pie.Would it be ill advised to run a permanent fuel pressure gauge on that port on the rail? Or would be best to run it in the line somewhere?
30 isn't enough. I'm not a fan of the goofy Vette filter/regulator. But in your case it is the cheapest part to go after.
What did you use in place of the vette filter to keep it returnless?
Had it been the return style you could have pinched the return line and if your pressure came back you would know the pump is ok and the regulator on the fuel rail is leaking. I don't know how your return hose is set up off the filter but if there is a rubber section you could try to pinch it and retest.
It's quick and dirty to do before dropping the tank.
Well now I’m seeing like 80-90 psi for the EP381. Don’t know where I got those other numbers from
I just happen to have GM's service info open on my desktop in front of me. So I might have cheated a little.Zoomad beat me. And responded more thoroughly. Pizza joint and beer has more of my attention!![]()
If you have the Vette filter and regulator combo I don't think pinching it off is going to do it. I have the same setup, don't quote me on this but I would be looking specifically at the pump unfortunately. Where did you get it? Wondering if it is a Chinese knock off that is floating around?
