Hey guys, I have an lq9/4l65e out of an Escalade in my '91 burb. It starts up every time, and runs great in the beginning. Once it warms up and gets to operating temperature it acts crazy. Most of the issue is when idling in gear, not in neutral or park.
I have long term fuel trims way off :
Bank 1 is at -16%
Bank 2 is at +25%
Also when at a stop in gear, the MAF is pulling about 3lbs/min and my fuel rate jumps over 2gal/hr. All of this is happening at around 550rpm...as opposed to around 1lb/min and 1gal/hr normally in park or neutral.
This is also mind boggling because when stopped facing up an incline, giving gas does nothing and I have no power to move at all. Thing just lugs at around 550rpm and stays still.
Engine codes present are Bank 1 Rich, Bank 2 Lean, Knock sensor circuit low.
I'm running a return style intake with the typical multec injectors.
Thoughts???
Bank 1 is at -16%
Bank 2 is at +25%
Thoughts???
