I have a 2002 truck harness for 99-02 drive by cable engines. This is one I made stand alone for a engine that I will be using in the future. This is for auto trans 4L60E. It has a fuse box attached. There is a plug with a short set of leads for interior connections. All new tape and loom. Pcm is flashed with emissions removed. Electric fans enabled.
I'm interested to see if anyone is doing a LS based swap that needs a stand alone harness. I would still need a good stock harness / PCM in return to do the stand alone on mine again.
I figure $400 exchange for stand alone harness with flashed PCM would be fair?
I have $200 invested in parts, $100 for PCM flash. About 8hrs of my time.
I figure I can do a few of these if there's enough interest. Try and help fund getting my project closer to needing the motor. I can be reached best by phone or text at 413-522-6764
