Those are hard to weld 3/16" down3/8 nut + mig welder + die grinder to clean rusty stub first .
Weld on let cool . Heat with torch and dump cold water on and spin right out .
And 8mm tap to clean junk from holes .
I have done so many I dont want to do them anymore .
But what ever works for you and gets it done !
EXactly . . Done it many times . .Nah just filler on up. Its not gonna weld to the aluminum.
Lol, knocked the drill off the stooldid you already break a drill bit?
I'm in Comufornia, we don't have heavy corrosion here.....Won't stick in there .
And if real heavy corrosion I die grind the 2 to 3 threads off the head so the stub is not spinning threw the junk .
We know these bolts and holes are LONG so a few threads missing is not a deal breaker .
