Hi All!
so my son and i are doing a father son project on a 1988 K5 blazer with the 350 in it. my son has been junk yard hopping for parts for our truck and has found an engine we may want to use in an LS swap for this truck. the current engine is burning oil ( blue smoke on start up so might be heads and valves but not sure). he found a 2002 escalade with the LQ9 6.0 liter (345 hp version). the motor will be an over winter project. we have to inspect it and make sure it is a good motor. if we get this engine and all the wiring etc, should be also get the trans that is in the truck? if we go with the 4L80 ( I think) that is in the escalade, does the K5's transfer case work with the trans and engine combo?
i also need the stuff from the donor truck that i need. i have researched and it seems that i need the
TAC module,
PCM module
pedal assembly
all the 02 sensors
a/c compressor
full engine wiring harness
exhaust manifolds
all the coil packs
and am wondering if we should use the electric fans from the caddy/. also wondering if we should use the trans and transfer case instead of the one in the blazer.
my son is heading back to the junk yard tomorrow and i am trying to get him a full list of stuff to get. we would use the factory harness and keep the motor stock for now. we are planning an install over the winter but have an oppertunity to get this stuff cheap now.
any help would be appreciated on what to get from this donor. it looks totally intact and just got to the yard recently
thanks!
john
TAC module,
PCM module
pedal assembly
all the 02 sensors
a/c compressor
exhaust manifolds
all the coil packs
thanks!
john
