Yes, that's very true for a paying customer, the labor time can quickly overshadow the upfront parts cost. I think the numbers change a lot with volume, as there are batch licenses with HPTuners and EFI Live for all cars of a type, instead of $100 in credits per vehicle. I've always been on DIY side of just doing one vehicle at a time, for myself, at my own leisure. If I'm going to be tinkering around the shop doing something, it might as well be re-pinning a factory harness, save the $500 and pay somebody $50 to cut the grass instead.Yes, that is correct, if you have the time. I just don't have time to tune with the stock ECU when the aftermarket ECU can be tuned live while the engine is running and see the results immediately, and these days does it by itself most of the time, and it is definitely more versatile than the stock ECU. Also, the harness comes plug and play for some applications vs hours of depinning, cutting, removing, etc. I use the factory ECU in the factory vehicle, because it's also integrated into other aspects of the vehicle most of the time. Once you remove the engine from the vehicle, I'll take the aftermarket ECU pretty much every time because of the amount of time it saves.
BTW, are you saying you can buy an ECU at the parts store in a pinch? I'll be honest I've never looked. The Holley Terminator system uses all the stock sensors except the 02 sensor, which is from an Audi or something like that. All of the sensors can still be purchased at the parts store if you know what vehicle to look for. In the truck I keep a list of the sensors in the glove box along with what vehicle they came out of.
But with the LS engine it's easier because you just need to know what vehicle you took the engine out of. But with a tuned factory ECU you would still need your laptop and then a new code from HP tuners for the new ECU, then pay more money for a license for the new ECU, it still wouldn't be an easy fix if you lose the ECU. Luckily that's rare.
I guess what I am saying is the ECU and wiring harness are the only thing aftermarket really. Neither of which are easy to change with a tuned stock ECU or an aftermarket one.
Thank you for standing up for of the stock ECU, I always respect your opinion Luke.
I think I was partly jaded about the aftermarket EFI because of all the horror stories getting things running right after spending $3k on the setup with the promise of "self learning". Meanwhile you could get the factory ECU on for $500, pay a tuner $500 and be done. Anecdotally, the aftermarket setups have finally come into their own where they work more as advertised. I think part of the confusion is always user error because you still have to understand how an EFI system works whether using factory or aftermarket. You can't self-learn around a giant vacuum leak, mis-wired sensor or a host of other physical problems that can easily arise after an engine swap.
BTW, HP Tuners does have real-time tuning that adjusts tables based on O2 while driving. I haven't tried it. I believe EFI Live has the equivalent. You do have to flash the adjusted tables in when it's done.
