Doing manifold gaskets for a friend on his 06 Denali with a 6.0. (Truck is mint, and gorgeous, and I'm kinda jelly of it.) I can see one broken bolt on the passenger side, I grabbed a wrench and the other bolts loosened up easy. I Just youtubed it and the video I watched the guy ripped out all the bolts with an impact and said they pop the heads off from heat cycling. The broken bolts he got out real easy with a stud puller.
What are your experiences doing these? Should I just put new manifolds on it right away? They are dirt cheap on Amazon, so that tells me that is the common fix.
