- Joined
- Jul 18, 2000
- Posts
- 1,695
- Reaction score
- 2,115
B454rat,
Like Russel said, $500 is a steal for all of that! The way I have the gauges set up in my old square bodies is no different than how they were originally but on a newer truck like yours gets more complicated but not difficult.
Keep in mind, the 8.1L was used in the 2001/2002 3500-HD truck backed by an 4L80E or NV4500. The 3500-HD was a GMT400 just like your Tahoe. With that, I would recommend finding a factory GM service manual / diagram for that truck to help you repin your current harness to work with the 0411 ECM on the 8.1L. If your real lucky, you might even find a 2001/2001 3500-HD in a junk yard and use the entire harness from the bulkhead on. In fact, there was one CL here in CO about a week ago that was a rolling 3500-HD chassis being parted out that had an 8.1L originally but I can’t find it now. If it helps you at all with parts searches here is a VIN of one of those GMT-400 8.1L trucks > 3GBKC34G61M101958
As far as a harness goes, I’ve never been a fan of reworking harnesses but if you got your hands on a 3500-HD harness that would be the cat’s ass for a quick and easy install. Of course, if you used the Allison that would require some modification as the 3500-HD was not offered with an Allison, only NV4500 and 4L80E.
This GUY did an 8.1L into a 97 Hoe which is pretty much what you’re doing. While I don’t agree with all of his processes he recipe seems to have worked out in the end. He is also a member of the 8.1L Facebook group. Might look him up with questions. I can’t remember his name though…. Jake??
BTW…this is what a 3500-HD with a 8.1L looks like. They were a bit larger than a 1 ton with an I-beam front axle mounted to leaf springs. 2wd only although there are some 4x4’s that were converted by upfitters that are harder than hell to find. Cool trucks
An 8.1L in a 3500-HD
Good luck!
Good luck!
, should equal some fun.
