Ok I will first admit that I dont know a whole lot about these engines but decided to dive in a do a swap on my dd. Used lt1swap.com for wiring harness modification and had the computer retuned. Swapped engine in 85 chevy and it will not start.
What I know is that it cranks over, fuel pump is working and has proper pressure at test port. It seems that the coils are not getting fire but Im not sure if Im checking correctly. I have checked crank sensor and cam sensor for proper operation and it seems that they are working correctly and there are no codes on pcm. Where do I go from here? Im really starting to regret this swap so if someone could point me in the right direction I would very much appreciate it.
And hopefully my experience can help some others with no start issues.
awesome, thanks again.
