WOOS1
Registered Member
I have tried to search swap threads, but have been unsuccessful in my attempts. I am entertaining the idea of swapping a LQ9 into a 1990 K5. I have several questions for those experts out there. The LQ9 will be rebuilt and have a mild/moderate cam. I have access to NOS kits and there could be an occasion to spray a 150 shot.
Obviously a 4L60E will be the easiest to install, but I am concerned that it will not live long term. The max tire size will be 33" and the truck may occasionally pull a 3K pound trailer. I do not mind spending $3K on a built transmission, but don't want to do that to find out that it will only last a year.
If I do need to move up to a 4L80E to accomplish my goals, what issues must be resolved? I know that the case is longer. I assume that I will have to relocate the T/C rearward to accomendate, but I really don't want to lengthen/shorten the drive shafts. Is there a possibility to push the engine forward? If not, what is the reason: crossmember in the way? Can a new one be fabricated? I read that the Dirty Dingo mounts are good to use. I can get some different mounts thru my work that I may try just to check.
Obviously a 4L60E will be the easiest to install, but I am concerned that it will not live long term. The max tire size will be 33" and the truck may occasionally pull a 3K pound trailer. I do not mind spending $3K on a built transmission, but don't want to do that to find out that it will only last a year. If I do need to move up to a 4L80E to accomplish my goals, what issues must be resolved? I know that the case is longer. I assume that I will have to relocate the T/C rearward to accomendate, but I really don't want to lengthen/shorten the drive shafts. Is there a possibility to push the engine forward? If not, what is the reason: crossmember in the way? Can a new one be fabricated? I read that the Dirty Dingo mounts are good to use. I can get some different mounts thru my work that I may try just to check.
