Came across two 245/75-16's that were brand new spares,under pickups and never were taken down..rims are JUNK though,completely rotted,the whole center of one rim was missing--I will try to get a picture of it,if it doesn't crumble to rot flakes when the tire machine breaks the beads..but that's another topic..
Question I have is one tire is a Firestone "LT" load range E .
The other is a B.F.Goodrich ,thats a "P" (passenger) rated,cant see a load range letter,I'm assuming its "B"..this tire naturally has a lower load rating,but is still plenty sufficient for my truck's needs..
Now I know the LT tire will either have more plys or thicker ones that the "P" tire,I'm just wondering if I pair these two up on the same axle,if they will fight each other or make no real difference (as I've noted in the past when I had "E" range tires in the rear and "C" rated ones up front--I saw no disturbing handling issues at all)--but I had pairs of each on each axle,not one LT and one P rated tire..
I can have these tires for free,and they still look new,not all dry rotted,they still have nubs on them..and are equal in diameter,the treads are almost identical too..
My thoughts is my 3 ton ingot wont handle any worse than it ever did,but I would like to know if anyone else has run an LT and P rated tire on the same axle and had any issues before I go thru a ton of work dismounting tires ,etc..
If I had too,I do have another "P" rated tire the same size,but its about half worn,I'd rather use the ones with like new tread ,especially in winter..
