Roundeye lives matter!
Dean does the wire harness from the steering column to the gauge cluster match the new cluster printed circuit?
I had issues with the printed circuit itself. Check closely each circuit on that flexible sheet to be sure there isn't a tear or hot spot. Also that the tabs making contact are in good condition!
Yes they are the same 9 per side 18 all together. I tried 6 different clusters with no luck. Albeit they we kind of dirty from garage dust.
I stuck the original to the truck back in it for now...We can get back to it later.
The reason I took it out is that the shift indicator tab for the cable was broken and I wanted to change the cluster with one that was not.
After the other clusters wouldn't light up I was going to put all the original gages in a non broken housing. But they are actually different.
I just getto fabbed a screw in the dash for the cable.
