M1008 Cucv Ls Swap Cadolet Build, long range Blazer Bash Project
Converting my M1008 from 6.2 Diesel to LQ9 power
Well I checked my fuel lines on the firewall and one was a little to close to the exhaust so i used some self tappers and a few clamps I secured my fuel lines better than they used to be so that's one thing off the list. I want to try to get my spartan locker (dana 60 lube locker ordered) and shifter installed asap.
How do I get my tach to work? I grounded it, the wire from the harness that says tach is connected to the white wire off the tach, back is grounded and red is connected to a 12v ignition source on the fuse block and it won't move. What am I doing wrong?
Worked on getting the shift console installed. The base is mounted to the transmission tunnel and ill get the shifters mounted and cables run.
Also looking under the truck I noticed all the motor mounts bolts were missing their nuts. So time for a bolt check all around.
