M1008 Cucv Ls Swap Cadolet Build, long range Blazer Bash Project
Converting my M1008 from 6.2 Diesel to LQ9 power
That looks great. I also dig the camo paint showing through in spots, though. Can't go wrong either way!
I got the rear brakes sorted today. Whey were about 30 %left on the shoes but the drums were scored and beat up. So I had the machine shop turn the drums and I installed new shoes and springs. Everything was in great condition for being 40 years old. It also solved my brake issue with the warped drums.
So I got the passenger side shock mount done. It looks good imo. While doing the drivers side I was measuring the distance between the bump stop and the spring. The passenger side was 8 inches, the drivers side was 6 and a half inches in height. So my driver side lean is definitely a spring issue. So I need new springs.
They all lean
Get one of those pulley steering wheel systems like the USPS and sit on the other side of problem solved
Hahahahahah yeah but mine leans bad. I ordered a set of these to see if they will help, I was reading online where a guy had drivers side lean and these helped.
My rear had a lean due to me not being so exact when doing my 64" spring swap. I just built some custom blocks with one side 1/2" taller to fix it.
I used those on my 1009 to help the passenger side sag. The two batteries + the soft Skyjacker springs make it lean that way. Also hooking the sway bar back up for street driving helped.
