m1009 wipers work on high only
84CUCV
3/4 ton status
NJ for now
work on high and they dont return. so what do i need to check? thanks
The not returning is a side effect of low not working; they return using low speed. Check all the electrical connections at the wiper motor first, but its possibly the low speed windings in the motor are shorted.
Check the resistor pack mounted on the blower cabinet as well. Usually at fault when you only have high speed. Wiper return is a function of the motor.
checked it out. still not working. motor is fine. could it be something in the steering column?
