MAJOR trimming?
As I mentioned above The more you move forward to get the tire out of the firewall the rad support becomes the issue. I am thinking about cutting everything under my headlights out and re fabbing that portion of the inners.
then it comes down to... what easier to take care of, the firewall or the radiator support?
I got into my firewall this weekend... Just a little, but I had my oldest boy beat it with a hammer back at camp...:D
I'd say the firewall is easier... But, I was really stuffed when that happened... You would need some really soft springs if you move the axle forward to get into the firewall...
Yeah the firewall is simple..BFH :D
I posted a picture way up on top of my rubbing on the rad support. Its really just the lower portion in front of the tire. I don't think it would be too much of an issue to fix. I bumpstopped my uptravel, and it is not much of an issue anymore unless I am really stuffed and turned full lock I get a little bit.
Yep, BFH...
I haven't done any bump stops yet...
Here's where I got into the firewall on the passenger side...
