after recent tool losses, I'm pretty certain I'm gonna pull the trigger on getting into another battery system... my current snappie and Mac set up's are in disrepair and no longer viable after the storm..
effectively all I'm running now for Mac is a pair of these right angle drills (1 backup) a couple batteries and the flashlight..
Snappie, all I have left is a 13 yr old hammered beyond belief 18v 1/2 impact that still works surprisingly well, if I had a charger..
plus I'm down to 1 or 2 good batteries..
their 1/2 impact is unmatched, but with just a selection of 1/2 drill, the saw, killer 1/2 impact and a couple lights.. it's a bit limited.. and expensive..
so makita or dewalt.. same price, I'm going with the makita... and the tool selection is rediculous.. already eyeballin about 10 of em!
what i do wish someone made is a 110ac work radio that is also a charger.. that would kick a$$....
think I'll nut up at x-mas and buy the 6 piece combo..
http://www.ebay.com/itm/Makita-18V-...940?pt=LH_DefaultDomain_0&hash=item5ae5684a94
than definitely add the 1/2" impact after that for drive install/removals, motor teardowns, etc, probably used thru eghey.... than the die grinder caught my eye for down the road...
but every piece in the 6 piece will get used often.. circular saw for wood supports while shrinking, sawzall, right angle with cutoff for hose clamps, etc..
anyway,
anyone running the newer Makita stuff?
I like the bigger battery LXT stuff..
plus I'm down to 1 or 2 good batteries.. their 1/2 impact is unmatched, but with just a selection of 1/2 drill, the saw, killer 1/2 impact and a couple lights.. it's a bit limited.. and expensive..
anyway,
