Manual to Auto?
Swanson52
Centennial, CO
Yes, I know, I can't make up my mind so bear with me!
I've been looking to dump my 465 in favor if a 5 speed, but now I'm considering ditching the manual altogether and going automatic. What I'm wondering is what I'm overlooking when considering a parts list. Here's what I've come up with (excluding tranny & tcase)
Auto steering column, trans cooler, trans cooler lines, shifter linkage, crossmember, flex plate.
Is there anything I'm missing here?
Is there anything I'm missing here?[/quote]
Driveshafts, wide brake pedal, kickdown linkage on tranny,safety neutral switch, reverse lights switch,pilot bearing puller, 2 gallons of trans fluid, sheetmetal patch on trans hump, vacumn line to modulator, I went from 465/205 to 400/205. PM if you need details
i swaped 465/205 to 400/205 with parts truck i had.
i swaped just the pedal assembly for auto.
swaped in 400/205 with driveshafts and cooler lines and crossmember.
then for shifter i used a lokar midnight series 23" nostalgia 2 bend shifter with swaped on pistion shift knob. it bolted to the tranny and fit up threw the 4 speed hole. and with the 4 speed boot on the floor looks like a 4 speed still.
