Manual window regulators
I was guessing, :haha: I had a set of manual door panels to swap in on mine when I did it... :whistle:
This is almost to the level of stupid easy. The only recommendation Id make is to make sure you have 4 total extra bolts for the regulator because my power ones had two studs, so i stole the screws off the handles for now since it still opens with one, and the window studs stick right through the power switch location. Super simple swap.
the 1/3 down is perfect, along with a helping hand to hold the window, and a window handle without the clip so you dont have to worry about removing it a couple times to get window reg in right position. Oh, and remove the power window plug from motor first, and you have to remove the inner door handle, you can keep rod attached, to slide the reg out.
There are small differences with the 73-76 compared to the 77-91 Manual regulators, just in case someone has bad 73-76 regulator and wants to swap to newer ones. The Window crank shaft is shoter on the 73-76 so if u swap to a newer on it sticks out of the door panel too far.
On 73,74 for sure (maybe the 75 ,76) the Tracks in the door and on the window are smaller and dont accept the newer larger wheels that are on the newer regulators. Other than that its all the same.
