Master Cylinder upgrade. Can I eliminate proportioning valve?
mauch66
Newbie
Minneapolis
I have a 70 k5 with front disc brakes. The master cylinder needs to be replaced and I am wondering if there is a bolt on upgrade from a different year (which years will work for this model?) where the master cylinder proportions front/back automatically or will I need to keep using my old proportioning valve? If anyone has info about this, I would greatly appreciate it.
I dont know of any master cylinders from newer years that have a built in proportioning valve. But If the proportioning valve in your truck is the orginal you might want to think about replacing it also.
