I apologize I have a couple of related threads going on this. I want to ask this question specifically. Has anyone with a flexy suspension hung their K5 by the frame to see how steep the angle come out? Trying to guesstimate based on static angles and droop estimates just seems really weak.
In my case, my rear shaft sits at nearly 20 degrees when parked, and I estimate the T-case sits back 5 degrees, so 15 degrees on that shaft to start. Up front, it measures about 15 degrees, so 20 degrees with the T-case penalty. Using some fuzzy math, I could convince myself these could go as high as 25 in back and 35 in front, but I don't know if this is realistic. I just did the geometry based on droop estimates.
