treetrunk
Registered Member
Any idea what the maximum amount I can rotate the pinion up safely without starving the pinion bearing or puking oil out axle seals Preparing to do a cut and turn for a very tall truck. Also it has a 700r4/205 with the short conversion So sticking with 1310 cv for now as that is all that will fit by the oil pan. Otherwise I would spend the money on hi angle 1350 or 1410 driveshaft and not rotate the pinion to extreme. Also has b52 springs in forward mount so I am stretched out. Thanks in advance.
#tonsofroom
