Max pinion angle gm dana 60 cut and turn
Well, sounds like you need to swap to a 4spd. :D #tonsofroom
I would certainly do that. Sadly 465/205 combos were a dime a dozen back when I was a young man and a gave several away for a dime. At this point I just want to get this thing complete and in the stable so I can finish 2 other half assed projects. Almost there.
If you weren’t going to use it much I’d say try a single joint set up but it sounds like you’ll be using it too much.
