Will a 35/10.50R16 or 35/12.50R16 tire, work on an 86' K30 with stock rims, 1" Zero Rates and 1" body lift? Fender trimming is not a problem, as long as the wheel wells can be kept.
Had in mind 35/10.50R16Swamper SSR Radials or LT315/75R16 (35/12.50R16)Hankook Dynapro MT-RT03.
If not, what is the maximum tire size that will work?
Eventually want to add a 4" shackle flip, crossover steering, 17x9 wheels w/4.5-5" back spacing, etc. and run the largest tire possible, with that combination. Should be able to easily run 37's but would like to run 40's if possible.
Want to maximize tire height with the above combinations of lift, 6" total maximum, and still keep the wheel wells.
