The oil pan progresses
I have finally got back to working on the oil pan. Here's a pic of what I have so far:
The side rails were cut out of 1.5x.25" flatbar, the front rail was cut from 3x.25" wide flatbar, and the rear semicircle was made from .375" square bar. The sheetmetal is .090" thick, and all the material is 6061T6. In order to bend the rear semicircle I had to heat it to 800 degrees for about 20 minutes and water quench it. This brought it to an "O" condition, making it soft enough to easily form by hand. I used a 5lb fire extinguisher as a form, and had to pull a little bend back out to get it to fit properly. Then I tacked it up on the engine, removed it, welded it, and put it back on to make sure it still fit.
The side pieces are 4.5" tall. I have to make the pan in two pieces - upper and lower - in order to be able to reach all the interior parts to weld them. I will fit and weld up the upper part, then I will separately fit and weld the lower sump portion. Then I will weld the sump to the upper portion. I have to do it that way because I wouldn't be able to reach and maneuver the TIG torch and actually see what I am doing in the bottom of the pan if it was one piece.
I tacked the sides on, then clamped them down to the bench before welding them up. I was able to minimize the warpage, although the rails did bow a bit. It isn't nearly the warpage I got with the steel version, and it will fit just fine. So far I am pleased with how it is coming along. The hard part was welding the long seams on the rails. The rest shouldn't be any problem - I may get some warpage, but nothing that will prevent proper fit to the motor.
I have to work on my crossmember this weekend, but I plan to get back on the pan first thing Monday
Here's a couple more pics:
My TIG is still pretty rusty. Also, the beads come so close to the bolt holes that I will need to spotface each one for bold head clearance. No big deal
