I have been running NV4500s in my off road trucks for quite a while. The first one I built I used a mix of Redline MTL and MT90 (they didn't have the MT85 back then) and it killed my syncros in about a year. I switched to running either the fluid straight from the Dodge dealer, or the Amsoil Synthetic Manual Transmission and Transaxle Gear Lube (75W-90 API GL-4) and I haven't had any issues. I run the same in the transfer case just in case there is cross contamination.All the gears work as expected, as do the ranges in the 208. The trans had what appears to have been gear lube in it. Visually everything looked very good, no debris or anything inside. I'm hoping the synchro's are fine as I really doubt the stuff that was in it was GL-4
I have 5 quarts of Redline Synthetic MT-85 gear oil which is GL-4.
The 208 if memory serves me just uses ATF?
