Meet Clifford
1977 K20 Custom Deluxe
All the gears work as expected, as do the ranges in the 208. The trans had what appears to have been gear lube in it. Visually everything looked very good, no debris or anything inside. I'm hoping the synchro's are fine as I really doubt the stuff that was in it was GL-4
I have 5 quarts of Redline Synthetic MT-85 gear oil which is GL-4.
The 208 if memory serves me just uses ATF?
I have been running NV4500s in my off road trucks for quite a while. The first one I built I used a mix of Redline MTL and MT90 (they didn't have the MT85 back then) and it killed my syncros in about a year. I switched to running either the fluid straight from the Dodge dealer, or the Amsoil Synthetic Manual Transmission and Transaxle Gear Lube (75W-90 API GL-4) and I haven't had any issues. I run the same in the transfer case just in case there is cross contamination.
Interesting that you had issues even running GL-4 fluids. I had always heard that was the critical thing was the GL-4 part.
Checking the Redline site the MT-85 is rated specifically for the NV4500
Assuming the synchro's are currently OK, I guess we'll see. :dunno:
I’m fairly certain that an ‘85 on up square crossmember made for a short-foot mount will work just fine - you could also just stick with your ‘84 and older “flat” crossmember and just add a spacer between it and the mount on the tail housing.
Add another vote of confidence for the 208 case being able to handle a little thicker oil just fine with no bad results - the bearings and planetary gears in a 208 don’t demand such thin oil as ATF.
Some cases can’t handle the thicker viscosity but it’s actually better for the 208’s inards.
Spacer sounds good...I do have the stock mount from the 94 and I can take some measurements of the current output and go from there. :waytogo:
Perfect weather for getting it done Rene! A bit humid but not hot, not cold.
And so wet out that it’s nice to be indoors.
Looks good! :waytogo:
