Member's truck database- post up
BowtieRed
Author
Winston-Salem, NC
Member\'s truck database- post up
I think I'm going to make a spreadsheet of member's trucks. Then I'll post it here, so post your truck's:
Year
Color
Lift
Tire size
Engine/trans/t-case
Axles
Misc.- Anything else you find necessary
Link to photo
this is for general viewing and so members can check on here if they see a K5 on the road and want to know if its a members.
Possibly a sticky?
78
red/white
10" Superlift
39" Mickey thompson
350/sm465/np241
14FF/10B
Open haeders /forums/images/graemlins/laugh.gif
Re: Member\'s truck database- post up
Body 84 (K10 shortbox)
Blue/Silver
6" Superlift, extended shackles, Echobit flip with stock 52s, 3" PA body lift
38.5x16x15 TSLs
350/SM465/NP 205
14 bolt SF gov loc/10 bolt open 4.10s
Link to pic
1987 Chevy C30/R30
black primer
none
265/75R16s
350 TBI/TH400
14 bolt open 4.10
Link to pic of tow rig
86 Chevy K30
white, probably spray can by PO, bondo
none
235/85R16
Nothing/nothing/nothing
14 bolt gov loc/60 open 4.10s
Link to pic
1971 GMC Suburban
Primer Black
4" Rough Country
35" MT/R's
388 cid SBC
D44, 14BFF 4:10's
/forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
'88 K5
black
2 1/2" lift, 33's
350TBI/700r4/208
D$$/locked 12 bolt, 4.56's
headers, dual, and homemade rear bumper
here too
or see the link in my sig.
1979 K5
Blue and White
4" bds front springs w/zero-rates & extended shackles
"Backyardbuilt" custom 5.5" rear shackle flip w/zero-rates
36x12.50/16.5 Goodyear RTII Hummer tires
350/700R4/NP203 w/part time kit
D44 front,4.56 and Detroit/14BFF rear with 4.56 and Detroit
Link to picture
'87 Burb
White/Black/Gray . . .
2 1/2" Ft Springs, 4" tapered rear blocks
32" BFG mud terrains
350 tbi / 700R4 / NP208
10 bolt F/R
Everything is going in the rebuild!
Pic.
1985 K5
metallic green with a white top(soon to have PPG black cherry)
pro comp 6" suspension, 3" body lift with raised bumpers, about 10" total lift
35x16x16.5 super swamper boggers/16.5x14 weld scorpio V's
built406SB/built700R4/NP241/14BFF with govlok/8lug10B/4.10's
Future plans call for a dana 60, 4.88 gears, even more HP out of the 406, custom paint and interior.
Well, if the 81 K30 deal go's through, my 76 K5 will be Blue/white,6.5" lift front/7" lift rear, 454, sm465/NP-205, D60/14bolt FF 4:56's. 36" Ground Hawg's. /forums/images/graemlins/thumb.gif If not then 400, TH350/NP-203, D44/14bolt FF 3:73's 36" Ground Hawg's. /forums/images/graemlins/blush.gif /forums/images/graemlins/deal.gif
1989......................Year
White.....................Color
4 inch EZ rides front.....Lift
ORD shackel flip rear.....Lift
37 SSR's..................Tire size
350TBI/700r4/np241........Engine/trans/t-case
D60 locked w/5.13 front...Axles
14FF locked w/5.13 rear...Axles
custom Staz beadlocks with bowtie emblems on the way
Pictures
1979
Black/Tan
4" Suspension
35" Interco TRXUS MT
350/350/203
10/12 Bolt /forums/images/graemlins/angryfire.gif
Piss on, Hummer sticker right side/Ford left sidePic Here
Year... 1981
Color... Flat Black
Lift... 4" suspension, 1" ORD BL
Tire size... 39.5 x 15 x 15 TSL's on Black 15 x 10's
Engine/trans/t-case... 6.2 diesel, SM 465, NP 205
Axles... D60 front, C14 FF rear with disc's and Detroit. 4.56 gears
Misc.-...Az-Kickin anti wrap bar
Link to photo... http://coloradok5.com/photos/data/500/1019Lower_Hell-med.jpg
Rene
1989 Chevrolet V-10 Blazer, Grey
Stock 350 with full exhaust and headers., 700r4, 241(Aka poor mans doubler)
Locked 30 spline 10 bolt front with ARB and 4.88's
Locked 6 lug 14 bolt SF rear with disc brakes and a Detroit and 4.88's
Front suspension is stock rear springs, with 14" travel 2.5" Diameter Race Runners. Front axle moved forward 2"
Rear suspension is 6" lift springs that have sagged and I have a 2" longer than stock rear shackle in the back. No shocks currently
Tires are 35" BFG Mud terrains on 15x10" AE 589's(yuck)
I also have crossover/highsteer. I currently dont run the highsteer because it hits my pitman arm.
Truck also has Toybox Off road Rocksliders or Sullibuilt rocksliders. I made the tube front bumper and shock hoops. Front fenders are also cut, and inner fenders are gone.
1987 M1008
OD green
6" tuff country
38"michelin XL
468BBC/SM465/NP205
Dana 60 welded/14BFF detroit/4.56s
ORD crossover/hysteer,hydro assist,hydro winch
1979 k5
305 sbc
th-350
np-203
cammo
33" tires
3"body/4 "skyjacker sus.
10b/12b
side pipes
/forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
Year 1984
Color Rootbeer Brown
Lift 6" Procomp with homemade shackle flip
Tire size 35x12.50x15 bfg muds
Engine/trans/t-case 350/350t/208
Axles 10 bolts 456's rear Detroit locker front auburn locker
Misc.- /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
Link to photo http://coloradok5.com/photos/data/508/15703000_0113-med.jpg
/forums/images/graemlins/k5.gifWow where do i start
Body 1985
Color Ok right front fender bright yellow,left front fender army green and white,hood and doors white and rust,tub army blazer and green,tail gate black and so is roof.
No lift at time (looking at a 4 in lift)
Tires 31in
Engine/Tcase/Tranny carbed 350(till spring then it will be a fuel injected 350) with headers and true duals, 208,350th (changed from 700r4)
Diffs 10 and 10 (till spring then it will be dana 44 front and 12 bolt rear)
When i am done with the body it will be all yellow and black 4 in lift with 33 or 35 in tires.All i need for the body is driverside fender and 2 good doors.Also in the spring i am going to be putting a family bar and a 91 gmc front on it.this monster is a work in progress.
Body 1972
Color copper
no interior sept the dash
no lift
no motor
no t case
no tranny
diffs dana 44 front 12 rear
it is going to the crusher in the spring So if you need any parts pm me for parts
M.N is the location/forums/images/graemlins/k5.gif
How bout location??
1989
Dark Blue
2.5" TCI all spring, 1" ORD Pucks
33" pro-comp A/T's
350/700r4/21
Stock 10 Bolts
Soft-Top in the summer
Pic (w/o Lift)
1990 Suburban
Black over grey, 2 tone
4" TC EZ ride
35x12.50x15
350 TBI 700R4 NP 241 400 sbc to come....
2x10b's, 3.42's for now D44,D60/4.56/P/L's
Many more mods to come....
