R
RIPPEDK5
Guest
So with the install of my 14 bolt in the rear of my 2005 silverado 1500.
The front might not be up to par in these categories:
1) Height: the torsion bars are cranked all the way and may not be enough height to be level to the rear...without a lift kit, any ideas to boost height for just the front?
2) track width difference: I plan on some sort of rim change in the front. However the rear is 3"-5" wider then the body in the rear and by measurement standpoint i would have to add 4" on each side of the front to equal to the rear (which to me id fine) but again dont want to dump tons of money into the front or hack up the body to a point that the fenders are junk or mangled...(down time is a factor too)
3) need some sort of mudflap: anyone know of either a quality WIDE mudlfap or a place to get flat rubber to install in the wheel wells?
4) any other concerns should i be thinking about?
