broncoman6524
On my 383 with maybe 750 miles on it the pressure is as follows.
COLD:
Idle (500-700ish) roughly 45
Cruising (2000RPM) 60ish?
HOT:
Idle (500) about 15-20
cruising(2000 RPM) 40
This is with 15w-40 oil, I'm running a standard volume oil pump a deep pan with the sump to match it.
I read somewhere that 7psi at idle is enough to properly lube the engine? and its a minimum of 10psi per 1000 RPM. So technically everything is good?
COLD:
HOT:
