I am picking up a 82-85 K20 sat morning with @secutright, as far as I know this truck has been sitting for a while. Is there anything I need to know when attempting to getting it to start? I have my 1000cca battery from my k5 that Ill take. I also was told not to use ether? Never messed with these motors when they have been sitting.
Priming the IP?? is there a lever somewhere to get fuel from the tank?
Just need the 101 on bringing it back to life.
Also was told someone might have tried to steal it and possibly used ether so I dont even know if the motor is broken or what the deal is.. If i can pull it onto the trailer under its own power that would be nice.
THANKS!
THANKS!
AC 60G plugs are rated for many minutes on end, the original 9G plugs burn out after a few seconds.
Not a huge deal, but it caused some completely preventable starter wear, as fresh air was introduced to all the injector lines. It's easy to pump air through the fuel loop, but once it gets past the IP you may have several minutes of cranking (with many more minutes in between) before the lines get re-primed. When it does come alive, don't be surprised if you hafta floor it for 30 seconds or so...you may not get fuel to all cylinders initially.
