freaking heavy is what they weigh
Not sure but I bet they are 20 lbs heavier than say a Walker Evans beadlock.
Stock 12bolt H1's with drw70 and d70hd with 14bff hubs and disc conversion. track with is the same front and rear.
As for weight, I think my wheel/tire combo is about 150-175lbs per corner, maybe more. Crazy I know.
pics of the stance:
Whats the lift specs?
what size tires are those? do you have more pics of your shackle flip? where did you get your 3" 52's?...I'm kinda doing something similar at the momentlift is about 7-7.5"
front:
3" lift 52's with b52 kit and 7.25 shackles, 1" offset spring perches (axles is about 3" forward)
rear:
stock 64's with 1" zero-rate, home-made shackle flip with 7.5" shackle (axle pushed back about 3.5")
now that I think about it, my tire/wheel combo is probably about 200lbs per corner.
