k5 krawler 50
i've decided that i couldnt bring myself to beat up my k5 on any of the trails around here, so i have changed gears with it a little bit but it is all for the good. After talking with a lot of people i was convinced if i wanted to run the rubicon, fordyce, and other hot spots i needed something lower, smaller, and just more suited for crawling. As you can see my truck currently is too tall and only 2wd so it is not quite suited for crawling, oh well live and learn i guess.
So with that in mind i have decided to make some crazy changes to my k5 and my future crawler.......
now, the plans for now are to take the 14bolt and dana 60 out of the k5 and throw them under the 4runner with 37-38" tires. This will still be my dd, so i'm looking into some radials that size. I also picked up another top shift toy case which will be getting the 4.7 gears and i will be doubling it up with the existing one in there now.
suspension wise i'm looking at running some rears up front or some after market spring no taller then 3" lift. out back i'm still playing around with some ideas, but something along the lines of chevy 63's. My overall goal is to keep this thing simple and low.
but... here is the fun part; before all that happens i plan on making some minor changes to the k5. i have already started rebuilding a 205 for it that i swapped out some side work for from a guy, so that will take care of my busted 208 that is in there now, and to replace the dana 60 and 14 bolt i was fortunate enough to score a set of 2.5 ton rockwells locally for a sweet price. The guy i bought them from is a kick ass dude, and he even offered to help get them from carson to my place in reno.
I've already purchased some spring perches for the duces from ballastic fab, and they seem like a really sweet set up for such a simple piece; they should be pretty stout.
the plans for the k5 now consist of keeping the same suspension set up as it has now, except i will remove the zero-rates to lower it about an 1"; either 46" mickey t's or 49" iroks on 20" stazworks. Basically it is going to be a mud machine (i know we have a lot of it around here
, but like i said earlier i couldnt bring my self to beat the crap out of it).
I will be running the disc brake swap with the ford buss rotor and f550 calipers, along with a pinion brake out back. Here is a link to the disc conversion:
http://www.pirate4x4.com/forum/showthread.php?t=408046
Once i get the rockwells up here in reno, i will start designing my steering arm for the cross-over steering, and get that, the hubs, and the rotors machined back home. Other things like the diff covers being cut and modified along with some boot protection on the rocks, and some front and rear traction bars will also be added as well.
I am in school right now and also working m-f so progress will be slow and take place on the weekends, but as things start to unfold i will post up here with progress.
anyways, just thought i would share somethings that will be changing for my trucks in 09/10 and looking for some feedback on what you guys think. All the help the better.
(sorry for the blurry pics, but my bro's cell phone was all i had)
, but like i said earlier i couldnt bring my self to beat the crap out of it). I will be running the disc brake swap with the ford buss rotor and f550 calipers, along with a pinion brake out back. Here is a link to the disc conversion:
