gonefishin
set of non flat topk knuckles $20
2 spindles need new bearings $10 i have 2 spindle bearing kits i will throw in for 20 more
6 lug hubs rotors and caliper bracket needs bearings on one side $25 for both sides
warn prem hubs $40
factory hubs never tried them but everything looks good $20
30 spline front shafts 1 new super u joint on long side short side feels ok 1 stub is a little scored from bad spindle bearing not too bad full set $60
welded 30 spline open case $10
4.10 gears light surface rust looks to be ok $40
front housing $20
30 spline rear shafts $30 each $50 for the pair
Factory 30 spline posi $75 had this in the rear of my blazer worked good for a limited slip would be great for the front
Factory yokes $15 each
warn prem hubs $40
front housing $20
) but I was curious, might clear it up for interested parties so thanks for the info.
