mix n match 205
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Can you take a Ford input gear and put it in a Chevy 205. We are trying to mate a C6 to one but have the chevy drop
If its a 10 or 27 spline input on the 205 you will need to have a machine shop bore the case to accept the larger bearing that accompanies the 31 spline input.
31 and 32 spline input = big bearing
10 and 27 spline input = small bearing
There is also a rumored small bearing that will allow the 31 or 32 spline shaft to be installed without boring the case. I've never personally seen this bearing or even a part number to verify it's availability.
How are you going to do to seal the C6 tranny from the t-case. All Ford NP205s have a front seal housing, while Chevy NP205s with the figure 8 bolt pattern don't.
PaulC
Well he's going to need to make an adapter anyways so i'm sure he will have the adapter made so that the seal is in the adapter.
