This is actually not about my K5, but I think the people here may be less likely to get all uppity than the people on the Tacoma forum... I need to change the oil on my truck, and the recommendation is 0w-20. That always struck me as crazy since I live in Arizona... anyway, since my various cars take oddball amounts of oil and I need to top things off sometimes, I have ended up with a leftover 1.5qts of 5w-20 Mobil-1 and 2.5 qts of 5w-20 full synthetic Valvoline. I thought, "I'll go get some 0w-20, use the two leftovers and make up the difference with the 0w-20". The truck takes 5.5 qts or so at oil change.
But going online, articles and people seem to be super anal, like you can't mix weights or brands without destroying your engine, or doing some chemistry experiment in your engine with unknown results. I find this hard to believe. Is it really the case that if you are on a road trip and need to top off, that you are risking your engine if you can't find the same weight and brand/type as you originally used? Would the engineers at these companies not make their oils inert enough that they could operate in the real world where people are likely to mix?
I'm not poor or anything, but throwing away all my scraps of oil seems like a waste. I only need so much for chain lube and lawn equipment.
