Anymore info on the cam. Solid lifter cams are not that popular anymore so I would be suprised if somone put one in a truck. Before you change the cam pull a valve cover and check out the spring set up, maybe even check the lift.
Rhinopkc said:As stated previously, if you raise the idle that high, you'll need a higher stall speed torque converter (or a manual tranny). It'll probably scream once you get it rolling!
1985_K5_Silverado said:It might be a great cam for racing in mud drags. Maybe in a vehicle that was a ton lighter (a nice little pro-streetish 64 Nova). To get an engine with a really huge cam to idle well enough, you might have to bump the idle up to something like this:
http://www.nhra.com/sounds/topfuelidle.wav
Rhinopkc said:If your you're happy with the power curve of that cam, I think a manunal trans would be the way to with that engine. The whole combo wouldn't be my first choice, but if I were going to run that engine I would definitely run a high stall auto or a manual trans behind it.
!). I hope all of this helps you, I'm sorry to keep telling you to change stuff, but that engine is really set up for a light weight street car.i'm really feeling bad about buying this engine... what should i do to make it perfect for my Truck??Rhinopkc said:By High Stall I am referring to the stall speed of the torque converter, you'll need a higher stall speed converter to match that cam. With the idle turned up high and a stock converter, you might feel like the engine is trying to pull through the brakes when you are stopped. You also need to match your converter's stall speed to your camshaft's power band for best performance. I wouldn't go with anything too high in your case, just enough to make up for the high idle. Look at the TCI Breakaway, that seems reasonable(well as reasonable as you can get when putting that kind of motor in a Blazer!). I hope all of this helps you, I'm sorry to keep telling you to change stuff, but that engine is really set up for a light weight street car.
aknight_sa said:
