Modified shift rails
spoolnaround
Kingsburg Ca
Steve I cant find any info on modified shift rails on your site. I thought you guys had shift rails done for front wheel drive only, or so you only modify what we send you? Either way what do you guys charge to modify them/ outright modified rails? One of these days I will get this thing in.
When I lasted talked to him he said they only modify customers own shift rails to avoid anyone getting a set that might give troubles because of a bad seal area. They were also $60.00 to modify YOUR shift rails.
We do modify the shift rails but it's not something that I want to make a lot of noise about so it won't be on the site for a while. It's $65.00 to do them and at that rate, it's not something we want to advertise much. We need the pair to work on and we return your rails to you.
