I have a 76 K5. It has the stock 12b rear and a Dana44 front (I think) with 3.08 gears. I've been running 33x12.5's for quite some time (rear tires are about shot so 25,000 miles or so) with a very stout motor but am now wanting to go up to 35x12.5's. I've been reading a bunch of threads here about swapping in a 14bFF and Dana44 from a 3/4 ton but still have a few questions.
I primarily use the truck for hunting. No mudding or crawling etc. I'd definitely like the advantage of taller gears particularly when I move up to 35" tires. I don't plan on going bigger than 35's because I don't want to lift it any more. Is the 12b, Dana44 combo I have now adequate, assuming I re-gear those, or am I just asking for trouble? From what I've read it seems like the 14b/Dana44 combo is quite a bit stronger than a 10b/10b setup but I didn't see anything saying it was way better than a 12b/Dana44 combo.
For a swap into a '76, what else will I need (aside from the 3/4 ton axles)? Am I correct in my understanding that if I get donor axles from a 3/4 ton I won't have to relocate spring perches, i.e. both axles will bolt right in? Will I be able to re-use existing rear drive shaft (brand new with the lift kit)? Front drive shaft (brand new two years ago)? Will I need special u-joints? I've already got extended steel brake lines; will I have to change those out? I've read about changing out brake backing plates on the 14b but does that only apply to newer K5's?
If I can pick up a set of 3/4 ton axles for $300 and go through them replacing seals, bearings, brake components, u-joints, ect. and get a set of 8-lug wheels am I going to be at roughly the same amount of money as a gear swap in my current set up? Or is the axle swap going to be less money?
I'm not trying to be cheap about this but if I really don't need the 3/4 axles for my rig it's a lot less work to just re-gear the existing setup and buy new tires. Please give me your honest opinion.
Thanks,
OM Gang
Thanks,
OM Gang
