Motor mount bolts size?
Art'74
OKC
I am putting a 454 in for a 350 and do not have the motor mounts bolts and want to get the correct size.
Please share with me the correct size/thread/length or whatever info. I need to go get the correct bolts for the motor mounts.
TIA.
Art
mount to block is 3/8" x 1" or so. mount to mount is 1/2" I believe, maybe 5" long??
If you're replacing a 350 with the 454 then all the bolts you currently have will work.
Sorry about NEI.
I was asking about the bolts/nuts/washers that go thru the the mount not the mount to the engine/frame.
Just FYI, I don't have the bolts that came off the 350 so that is why I was lost.
Thanks for the replies.
Art
